Windwing won't close
Old Jun 28, 2005 | 10:59 PM
imlowr2's Avatar
imlowr2
Wink Windwing won't close
Is there a way of adjusting the windwing? My passenger side windwing has a gap of about a quarter inch or less and won't close flush with the rubber seal.
Old Jun 29, 2005 | 12:47 AM
Randy Jack's Avatar
Randy Jack
Ed -
I had my windwings apart last year when I put the lock handles back in the frames. Without seeing your setup, it's difficult to be sure, however (since not being sure never has stopped me), it sounds like your rubber seal is not seated properly. Perhaps cutting the back of the seal to get it thinner would allow the wing to seat closed.
Just a guess.
Old Jun 29, 2005 | 05:10 AM
himmelberg's Avatar
himmelberg
Lowr... yes. The divider bar is adjustable. If your wing glass has been replaced check to see that your glazier didn't get too enthusiastic with his measuring and leave a little extra sticking out aft. Check your shop manual for the adjustment.
adjustably, himmelberg
Old Jun 29, 2005 | 06:39 PM
imlowr2's Avatar
imlowr2
It does appear that the lower portion of the glass is out further than the top. I tried to push it in more, however I'm nervous about breaking the glass. It is very slightly off and will close tightly if I push on the divider rubber. Any way of getting the glass further in on the wingwind itself?
Old Jun 29, 2005 | 07:11 PM
himmelberg's Avatar
himmelberg
Not sure about pushing the glass into the frame but you might get a glass guy to grind down the glass a bit if it's not tempered. There are adjustment screws that will let you move the divider bar aft.
If it's just a little bit then I'd start here. Then go to the glass guy.
good luck, himmelberg
Old Jul 1, 2005 | 05:33 PM
fatfenders56's Avatar
fatfenders56
eliminate 'em!!
GreatNorthWoods
15
Feb 29, 2016 06:54 PM
tvsjr
2009 - 2014 F150
Aug 1, 2014 03:20 PM
1997fordf350
Jun 25, 2013 07:04 PM
mgm5555
May 24, 2003 02:55 AM
