Windshield washer
Old Jun 21, 1999 | 03:09 PM
91F150's Avatar
91F150
Windshield washer
I've got a 91 F150 Custom. When I push in on the windshield wiper ****/button/switch, I don't get any mist. Anyone know how to check if this is the ****/button/switch or the pump? Wipers work fine when I turn the ****/button/switch. Thanks.
Guy
Old Jun 21, 1999 | 05:10 PM
Phillip Guidry's Avatar
Phillip Guidry
Windshield washer
The washer pump is located in the bottom of the water tank. With atest light hooked to ground, probe the bright colored wire { } and have a helper push the switch with the key on,the light should come on.If not,there is a break in the wire from the switch as long as the switch is good and the fuse for the washer circuit is good also.Now connect the test light to battery positive and probe the dark wire{-},the light should light if the ground circuit is good.If both tests past,you can safely change the washer motor by removing the tank,prying the retainer ring out and wiggling the motor away from the tank.
Phillip
Old Jun 22, 1999 | 08:50 AM
Greg Saunders
Guest
Posts: n/a
Windshield washer
WINGNUT-
15
Jul 31, 2010 10:49 PM
334eagle
May 21, 2010 08:35 AM
Hamberger
Jan 30, 2006 09:31 AM
76 F250 4X4
47
Oct 30, 2003 11:32 PM
dermstyle
Dec 21, 2000 05:14 PM
