330md timimg
Old Jun 27, 2005 | 10:35 PM
raymechanic's Avatar
raymechanic
330md timimg
i am dealing with a beast of a truck and i am at wits end . the story goes as such I have a 1972 f600 uhaul converted to a flatbed. the engine in it is a 1967 330md and matching 5speed tranny from a school bus the problem is noone can tell me the correct timing for this MONSTER I have been told 6.8.10;btdc can anyone help [ and dont say set by ear ]
Old Jun 28, 2005 | 04:41 AM
jowilker's Avatar
jowilker
Ray, I think 6º is a starting point. There are better engine tuners here than me, but my understanding is, you get a base line and start moving up until it starts pining and then you back off. Someone will be here shortly with a better answer.
John
Old Jun 29, 2005 | 07:37 AM
kristoph30's Avatar
kristoph30
Jowilker is right. The 1969 manual shows 12 degrees BTC on the 330MD (identification code C ) engine. Idle speed is 550 RPM with the high idle at 1200. Ford recommends that if "substandard" fuels are used, retard the timing to prevent detonation (not to exceed 2 degrees BTC). This engine has a 7.4:1 compression ratio. should make 17 inches of manifold vacuum (16 if it has a dual diaphram distributor.) Dwell should be 26-31 degrees. Point gap.017 Plug gap .028-.032. They rated this motor at a whopping 190 HP @4000 and 306 torque @ 2000 RPM.
The 330HD (code D ) - Everything is the same EXCEPT 6 degrees BTC and 2200 RPM on fast idle.
I don't know what the difference is between the 2 motors. Going through the book, the only differences I saw were minimal. It is strange that the 330MD spec shows 12 degrees when everything else is 6. (Exception being 477 and 534 @ 8 degrees.) 12 degrees seems kinda steep to me. Could it be a typo?? My gut says 6 gegrees.
Good luck!
Old Jun 29, 2005 | 12:19 PM
ovalholic's Avatar
ovalholic
6 is correct.
tylstruck
52
Jul 7, 2024 03:40 AM
candoo
Dec 18, 2014 01:56 PM
kelso1
17
Jun 4, 2012 05:13 PM
2speed
Nov 16, 2010 04:43 PM
arborguy
May 6, 2009 12:22 PM
