RPMs
Old Jun 27, 2005 | 06:28 PM
Thew's Avatar
Thew
RPMs
I have a 98 exp with a K&N and Gibson Cat back. I've noticed recently that my rpm are revving much higher at 70mph. I use to cruise at 2000 rpms, now I notice it's cruising closer to 2500 and then 3000 if I am going between 75 - 80 mph. Can't imagine this is good for the gas mileage. Any thoughts?
Old Jun 27, 2005 | 06:36 PM
RaftWW's Avatar
RaftWW
I'm no expert, but...
It sounds like you are losing O/D or your converter is on its way out. Definitely have your tranny checked.
Old Jun 27, 2005 | 08:30 PM
the4by4freek's Avatar
the4by4freek
Sounds like an O/D problem to me also. Are you sure the button wasn't pressed?
Old Jun 27, 2005 | 09:14 PM
Thew's Avatar
Thew
Thanks for the feedback. It definitely shifts into OD, as it downshifts when I take if off OD. One other thing, I need to replace my IAC valve as it has been humming on and off recently. Would this be somehow connected?
Old Jun 27, 2005 | 10:55 PM
Luzer27's Avatar
Luzer27
I turn 3000 RPM in 4th gera at 75-80 miles an hour. My truck is a 99' with 373 gears. This sounds normal. If ther was any slippage it would be coming form th e tranny and would be very short lived before failure.
-Dave
Christian Nestor
Jun 7, 2016 06:44 PM
mfrank1296
13
Feb 24, 2015 07:41 AM
spud57
6.2L V8
May 29, 2014 04:39 PM
Quizzack
13
Mar 29, 2014 01:06 AM
Steves55
23
Apr 27, 2013 06:24 AM
