Sponsored by: Auxito
transmission fluid
Old Jun 27, 2005 | 03:07 PM
sednec's Avatar
sednec
transmission fluid
I have a 99 f150 with E4OD transmission, I’m planning to change the transmission oil, what type of oil should I use? I know it calls for mecron, Is it ok to use dexron III,Mercon ? I wanted to use synthetic but all the synthetics have dual rating for mecron/mecron V and I read somewhere it was stating that ford does not recommend using dual rated transmission oils. Can anyone help me? <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Jun 27, 2005 | 04:24 PM
l-m tech's Avatar
l-m tech
mercon 3 is the only fluid i would use.also bump up to a larger trans cooler.this will help the trans and fluid live longer
Old Jul 10, 2005 | 11:07 PM
fordtech92's Avatar
fordtech92
merc V and mercon III are not interchangeable. if you use merc V in a trans rated for merc III from what I understand it can affect the seals. As far as merc III in a merc V trans, no one I talked to knows.
Old Jul 11, 2005 | 10:02 PM
PaulC's Avatar
PaulC
The safest move is to pull the dipstick, read what fluid it recommends, use that fluid.
MPD56
6.7L Power Stroke Diesel
1192
Oct 31, 2024 04:40 PM
smkf100
Oct 12, 2011 04:29 PM
TycoMax
Apr 24, 2011 04:14 PM
Harfend
Oct 15, 2010 07:46 PM
mehassel
Aug 8, 2006 05:46 PM
