Resetting the Computer
Old Jun 27, 2005 | 12:55 PM
Cannonball01's Avatar
Cannonball01
To reset the computer, do I disconnect the positive terminal or both on the batteries for 2 hours?
Old Jun 27, 2005 | 01:10 PM
Fordafied's Avatar
Fordafied
I don't think you have to do it for 2 hours. I would unhook them and then turn on the headlights to drain everything for approx 10 min. That is the way I did mine and it worked.
Old Jun 27, 2005 | 01:23 PM
Max1775's Avatar
Max1775
Hit the nail on the head! Turning the lights on drains any residual power left in any of the electronics. Undue both of the negative and positive cables cables before doing so, and 10-15 minutes should be more than enough. While you have the cables loose, it's a good time to clean and grease the terminals and connectrors.
Max
Old Jun 27, 2005 | 01:42 PM
Cannonball01
thanks, I appreciate it.
