Gas Hog!
Old Jun 26, 2005 | 07:50 AM
aslan45's Avatar
aslan45
Gas Hog!
My truck is a real gas hog, is getting thirstier and is pretty weak. Besides tune up, any suggestions short of major rebuild or bigger motor swap (I'm on a pretty tight budget)? Thanks in advance.
Old Jun 26, 2005 | 08:23 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
..Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 26, 2005 | 08:39 AM
jroehl's Avatar
jroehl
First off, I would suggest going to fordfuelinjection.com and follow the procedures there for KOEO and KOER tests (Key On, Engine Off/Running). Post back with any results and some of us may be able to help steer you in the right direction.
Jason
Old Jun 26, 2005 | 12:59 PM
phoneman91's Avatar
phoneman91
How much of a gas hog is your truck?? What is the MPG?? Any driveablility problems??
Old Jun 26, 2005 | 02:39 PM
pfogle's Avatar
pfogle
What is your truck? What year, model, engine, trans, rear end? What size tires? How many miles, when was the last time it had a FULL service tune up, oil, oil filter, air filter, fuel filter, plugs, wires, o2 sensor(s), cap, rotor, tranny fluid flush, and filter change? These things all can contribute to poor fuel mileage.
Old Jul 3, 2005 | 10:00 AM
aslan45's Avatar
aslan45
Got an engine code yesterday, then dropped off when slowed to about 35 mph. Will check all things mentioned above. It's a 93 xlt 5.0 efi w/about 103,500 miles.
Old Jul 3, 2005 | 04:46 PM
cjjeeper85's Avatar
cjjeeper85
how bad was the milage? I only got 10 mpg before i did everyting in my sig now i get 15 mpg.
