intake question
Old Jun 25, 2005 | 11:17 PM
Titantis's Avatar
Titantis
intake question
will a 302 intake fit a 351w?
Old Jun 25, 2005 | 11:53 PM
grampztoyz351's Avatar
grampztoyz351
Sorry to say but no it won't,thereis a big difference in deck height between the two engines.
Old Jun 26, 2005 | 06:52 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Titantis, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 29, 2005 | 06:40 PM
Titantis's Avatar
Titantis
thanks, i was going to put 351w heads on my 302 and keep the old edelbrck aluminum intake, but i guess i just have these heads ported and put bigger valves in them
Old Jun 30, 2005 | 09:10 AM
ronclark's Avatar
ronclark
You can put 351w heads on a 302 and the 302 intake will work. There's really no difference between the 302 and 351w heads except the size on the bolt hole where the head bolts go through and they sell sleaves for that. The question is why change when the heads are the same. Same valve size, same air flow except on some of the earlier model 351w heads.
edit: The heads that are different and require different intakes on a 302 or 351 is the 351c/351m/400 heads. Otherwise a 302 intake will fit 302 or 351w heads on a 302 and a 351w intake will fit 302 or 351w heads on a 351w
Old Jun 30, 2005 | 06:28 PM
Titantis's Avatar
Titantis
I really hadn't researched it but a relative of mine, who is a mechanic, said that 351 heads would produce more horsepower and torque because it was to his understanding that they had larger combustion chambers than 302 cylinder heads.
Old Jun 30, 2005 | 08:37 PM
Matt95L's Avatar
Matt95L
Larger combustion chambers will lower compression and decrease horsepower.Which 351 heads are we talking about?
Old Jul 1, 2005 | 01:56 PM
Titantis's Avatar
Titantis
hmm, I didn't know that, i'm 15 and really have no experience with working on cars except my 3 trucks, i just go by what I've heard, however I suppose there is a reason my parents wont let him work on their cars... But i had heard from him that the larger the combustion chambers the more air and fuel the engine consumed, and i just figured that meant more horsepower because more gas usually means more horsepower. I'm glad I joined this website, i have learned something.
Old Jul 1, 2005 | 01:59 PM
Titantis's Avatar
Titantis
I suppose I need to look at more diagrams of cylinder heads to better understand some of the things about them.
Old Jul 1, 2005 | 02:35 PM
Titantis's Avatar
Titantis
I just looked it up, I was totally wrong, thanks for bringing that to my attention man.
Old Jul 2, 2005 | 08:45 PM
grampztoyz351
I hung a set of '84 351 truck smog heads made a BIG difference in the way it ran, nothin trick in fact not even rebuilt. It ran a bunch better. Bigger valves even in abit larger chamber means deeper breathing. I thought he was tryin to put 302 intake on a 351. Sorry
Old Jul 7, 2005 | 05:23 PM
Titantis's Avatar
Titantis
so 351w heads do have bigger valves than 302 heads?
Old Jul 8, 2005 | 07:40 AM
ronclark's Avatar
ronclark
Which ones? A few of the earlier heads did but most use the same size valves.
Old Jul 8, 2005 | 08:00 PM
Matt95L's Avatar
Matt95L
The C9OE,D0OE,and GT40 heads have 1.84/1.54 valves.I'm pretty sure the rest of them including the 84 351w heads have the same size valves(1.78/1.46 i think) as your 302 heads.
Old Jul 10, 2005 | 01:22 AM
grampztoyz351
Most of the 351 heads have bigger valves
