Sponsored by: Real Truck
4x2 to 4x4 conversion-Is it possible?
Old Jun 25, 2005 | 04:16 PM
F15099's Avatar
F15099
I purchased a 2004 F250 4x2 CC V10 approximately 1 year and love the truck overall, but have had difficulty pulling my boat on sandy roads. I have considered selling it and just buying a four wheel drive, but I like the truck. How much would be involved in converting this truck to a 4 wheel drive? Would it be worth it or more trouble? And could it be done as good as the factory? Any suggestions?
Old Jun 25, 2005 | 04:22 PM
MobeyDick's Avatar
MobeyDick
I seen on one of these sites that some guy did it. Had pic to prove it. He said it cost around $1,800.00 and took a weekend! I highly dought the numbers but it looked possible!
Old Jun 26, 2005 | 05:30 PM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
F15099,
I have done several 4WD conversions on 2WD trucks in the past, and to do a conversion on a late model super-duty would VERY cost prohibitive, and quite labor intensive, to say the least. Call a few local truck wrecking yards in your area, and ask for a price on the just a few of the required components, such as the Transfer Case and electronic controls or manual shifter, Transmission, (unless you are going to pay to have your trans. disassembled to change output shaft), Front Differential, hub to hub, leaf springs, shocks and mounts, driveshafts, brakelines and hoses, etc. etc. etc.
If you happen to find where just these parts can be had for 1800 bucks let me know!!
Tim
p.s. sell the 2wd, find a comparable 4wd
Old Jun 26, 2005 | 05:40 PM
ford390gashog's Avatar
ford390gashog
this topic has been gone over a lot. it is not worh the labor and money. to get the full front suspension for a newer sd would cost over 3,000 easy then you need a new trans and transfer case if you get these new it will cost even more about 4,500 for both new then you need the vacuum hoses and all the wires selector switch another 400.00 and then you need a new driveshaft for the front about 100.00 so you are looking at almost 7,600 in parts alone
Old Jun 26, 2005 | 06:38 PM
TDCSILVER1's Avatar
TDCSILVER1
It is definetly not worth the money even if you could find someone that would do it well. What kind of tires are you running? If its just a small matter of traction in the sand try getting something more offroad aggressive than the stock 235's. I dont know how much sand you are talking about but tires really might help you.
Old Jun 26, 2005 | 07:12 PM
MobeyDick's Avatar
MobeyDick
Like I said I highly dought Numbers But$$
ford truck world. ************.com /forums/topic.t en-id-3795 74-s-2wd_to_4x4_conversion_picture_intensivee !
ccm14
2009 - 2014 F150
20
Jul 30, 2011 01:27 PM
bluesclu978
Feb 13, 2011 07:52 AM
rickf3504x4h
Dec 14, 2009 11:30 AM
russ&irene
2004 - 2008 F150
16
Aug 2, 2006 09:38 PM
jlyons
Jan 27, 2003 07:55 PM
