I have a 66' f-100 with a 351C and I want to put in power steering.
I have an opportunity to get a setup from a early seventies with a 300 inline six. Will this bolt up WITHOUT modification(cutting,welding).
I need one that will BOLT ON.
reDavef100
I would look for a setup for a 351c-351m/ 400m,engine brakets,pulleys and
also I would try to find the small trans cooler that mounts to the frame!
there are a great article in the tech area and you may also want to do a
search on the swap because you will turn up lots more useful info!
P.S Welcome to ( FTE ) !
