drop axle problem
Old Jun 25, 2005 | 09:31 AM
fish-albuq's Avatar
fish-albuq
drop axle problem
i just got my drop axle installed with new king pins and everything. i went to put it all back together and now the steering arm (horseshoe) that attaches to the drag link hits on my shock. have any of you had this problem? i just heated up my shock mount and leaned it out and it clears now i just never heard of this. thanks wade
Old Jun 25, 2005 | 12:33 PM
4tl8ford's Avatar
4tl8ford
Have you checked your tie rod ends, or your drag link yet? they are likely to be effected also. You have changed a major component of the steering geometry, and adjustments need to be made.
Old Jun 25, 2005 | 03:51 PM
mikesfordf1's Avatar
mikesfordf1
Had the same problem with my axle. Did the same thing with the shock mount
Old Jun 25, 2005 | 09:10 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
If your truck is the same as my 1950 F3 the shock mount is not the cause of your problem. Does your draglink point up instead of parallel to the truck? I can't remember the name off the top of my head but the part the draglink mounts too in the front needs to be heated up and moved down. Then the shock will fit correctly and you will be able to turn the steering wheel in both directions without the draglink running into the shock. Look through my old posts and you will find a post on this topic.
Haroldmac
Jan 31, 2013 08:54 PM
billcollector
Sep 16, 2012 05:14 PM
aero993
Apr 13, 2011 02:59 PM
salf100
Jan 26, 2011 10:39 AM
Cerb
6.7L Power Stroke Diesel
Jul 5, 2010 08:27 AM
