Trailer disconnect warning
Old Jun 25, 2005 | 09:07 AM
Hjudge49's Avatar
Hjudge49
Anyone had any problem getting a "trailer disconnect" warning when towing a trailer with electric brakes with a '05 PSD? When I tow my horse trailer, it continuously gives me the warning and beeps, but everything is hooked up and working, including the brakes. I can toggle the manual brake actuaator and feel them engaging.
Old Jun 25, 2005 | 09:55 AM
Ford_Doctor's Avatar
Ford_Doctor
Getting that message with a trailer connected means that you have an intermittent wiring concern. This could be anything from a loose connection to a corroded ground wire. One mistake I commonly see is that people dismiss the ground wiring included in the trailer connector and assume that the hitch provides the best ground circuit.
Old Jun 25, 2005 | 11:16 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Happy to see you back Hjudge....have you been out touring the country, and enjoying life?
Old Jun 26, 2005 | 10:34 AM
rblomquist's Avatar
rblomquist
I'm fighting this right now as well. I spent most of yesterday on the ground under the trailer. I did find 1 broken wire coming off one of the brakes and also found a faulty emergency disconnect switch.
Was thinking the integrated controller was too smart for itself (and annoying) but then based on what I found as well as remembering that with the other truck we "ignored" some occasional erratic brake manorisms I think it's actually a seriously well designed piece of equipment. Keeping my fingers crossed I fixed all the trailer faults so we can tow in peace next weekend.
Keep looking, if it's telling you something's at fault in the trailer, it's probably right, you'll find it.
Old Jun 26, 2005 | 05:13 PM
firesoutmatt's Avatar
firesoutmatt
I have the same concern . Just got back pulling my fiver 2k miles . Thing was driving me nuts then it quit then it came back. ???? I checked wiring ran voltage drop test on all the wires and everything checked out .When I did have the connector not in all the way it did the same thing but it also showed red on the controler.The other times it just beeped and sometimes said trailer disconected but allways showed green on the controler. I thought the same thing at first it was my trailer but I hooked it up to my freinds 05 and never made a beep.?????? I'm thinking wire harness on the truck rubbing somewhere but thought it would do it when trailer was not there. Quess next thing is checking truck wiring .
Old Jun 26, 2005 | 09:29 PM
Dejablue2001s10's Avatar
Dejablue2001s10
i have had this same problem when towing! I would like to get an answer to all this also!
Old Jun 27, 2005 | 07:40 AM
IB Tim's Avatar
IB Tim
The only time I have seen this is with a wiring problem, tuned out to be in the trailer harness all three times, three different trailers.
IMO Ford_Doctor is spot on!
Old Jun 27, 2005 | 09:05 AM
Hjudge49's Avatar
Hjudge49
I'll get out the tester. I seldom use this horse trailer, so I keep putting it off. Tim, I've been in Eurpoe for the last 3 weeks, now it's time to stay and play at home. We are planning to take the boat to the keys next month. I can't wait to see how the 6.0 does on a 450 mile trip towing 13,500 pounds of boat, motors and trailer with a 120 square foot "windbrake". This is the first thing I've ever hooked to that the truck really Knows is back there.
Old Jun 27, 2005 | 10:59 AM
IB Tim's Avatar
IB Tim
I want to go...life long dream to go deep sea fishing.....anywhere!
Old Jun 27, 2005 | 11:40 AM
jackofalltrades's Avatar
jackofalltrades
Looks like the cause of this issue has been diagnosed, So I'll attempt to hijack this thread.
Have any of you that have the 05' integrated brake controller ever used a Techonsha Prodigy controller? How do they compare to each other?
I have an 04' with the Prodigy, but have to wonder if I'm missing out on a good thing from Ford.
Old Jun 27, 2005 | 12:11 PM
roabdog's Avatar
roabdog
Boy, Hjudge49 you must be well liked on this site. Just last month I posted this same question about my 05 and only got two replies. Any how I will share my diagnosis. I checked all of the cables on the truck and could not find any problems. I then towed my Dad’s trailer with my truck and could not get it to act up. Then I figured that I would solder all of my connection that run under my trailer. Now mind you that my trailer is a 2001 so it is fairly new. I found one of the wires had been stripped back to bare wire and could have been rubbing against the frame. This was a manufacturing flaw in the trailer that I never noticed with my old break controller. Is this the demon that was making me pull out my hair…… I hope so I am going on a trip to Virginia this weekend and i will let you all know.
By the way I did find a connector under the hood on the driver side wheel well that connected the trailer connector to the mass of wire that goes into the cab. You might want to check that connector as well.
Rob
Old Jun 27, 2005 | 02:36 PM
firesoutmatt
Tim I would buy that reason but when I hooked up my trailer to my freinds 05 it never acted up and on mine it does. . It seems to be my truck thats the problem .I can go 500 miles and it will not act up and other times it goes off like crazy .Most of the time I only get a beep and nothing on the display .
I think its a homotron .
Old Jun 27, 2005 | 03:08 PM
roabdog's Avatar
roabdog
Smile
firesoutmatt, i would check that connection under the hood. I could see it being loose. i know that when i un-plugged it, the computer displayed trailer disconnected. just my .02
Rob
Old Jun 27, 2005 | 04:25 PM
IB Tim's Avatar
IB Tim
Fire it could be the truck, did not mean to say it could not be!
Old Jun 27, 2005 | 07:30 PM
Hjudge49's Avatar
Hjudge49
Thanks for the help guys. That will save me a lot of blind looking.
Tim, anytime you want to go fishing, just come on down. I'm retired and can fish any day. But August is DEAD ... October- November and March thru May are the best months for us in North East Florida. The Tuna and Marlin move North in the spring and back South in the fall and so we get the best fishing days then. Or come in September and I'll take you alligator hunting, it's much more exciting...
