302 hard starting when warm
Old Jun 24, 2005 | 04:00 PM
pburress's Avatar
pburress
I recently purchased an ’82 F150 with a 302 v-8. The motor has been rebuilt within the last 10k miles but was not idling well when I got it. A carb rebuild helped with the idle and now it runs well.
When cold, it starts quickly. But if it's warms and I let it sit from 5 minutes to half an hour, it’s hard to start. It turns over for up to 5 seconds before firing, I have to give it lots of gas to get it to fire, and it sputters when it first starts. After starting it is fine. Any clues what this might be?
Thanks, Phil
Old Jun 24, 2005 | 04:39 PM
Kemicalburns's Avatar
Kemicalburns
sounds like its running a tad rich. might bump your timing up a little as well
Old Jun 24, 2005 | 09:12 PM
pburress's Avatar
pburress
I adjusted these air mixture screws several times, the last was this afternoon. Each time I start two full turns out (counterclockwise) from fully closed. From what I've read I expected to have to turn them in clockwise (leaner, right?) from here but this seems to lower the idle and cause it to run rougher... I think I ended up over two turns out on both screws today...
On the timing, that's another question. If I set it by the specs listed inside the engine compartment, 9deg btdc, the motor seems to have no power under acceleration. If I turn the dist. clockwise and advance it the idle raises and it has better low end power. I don't know anything about the rebuild or if it has a stock cam in it still. Is there a way to set the timing in the ballpark without a light or knowing what it should be?
Old Jun 24, 2005 | 11:14 PM
Artistictouch's Avatar
Artistictouch
Ford didn't put heat sheilds on their starters which is likely the cause. Fords 302 is a tight engine placing the starter closer the exhaust manifold than other makes. This usually decreases the life of fords starters on the 302. Try a heat sheild on the starter and see how well it fires after a good running...you may be surprised.
Old Jun 25, 2005 | 09:48 AM
pburress's Avatar
pburress
The starter turns over fine, at a norman rpm... It just doesn't want to fire up.
I still think the answer may lie in the timing/fuel mixture. Any help on making these adjustments is appreciated. I will check for vacuum leaks also.
Old Jun 25, 2005 | 11:17 AM
munrow's Avatar
munrow
"Ford didn't put heat sheilds on their starters which is likely the cause. Fords 302 is a tight engine placing the starter closer the exhaust manifold than other makes."
Does your rig have Headers? Could compound the above problem.
After a few mods on my 351 (see sig.), I had the same exact problem. Turns out that I had the fuel line at an improper angle with it kind of arched above the level of the carb intake. I was flooding the carb every time I shut it off, and the fuel in the line drained down into the carb.
After re-positioning the line so that it was below the carb intake, I can start right up every time.
Munrow
Kemicalburns
when your timing it are you plugging the vacum advance? you can adjust the timing with a vacum gauge as well. but a timing light is the easiest. for something that you may use a lot you can get em cheap for under 25bucks. you should probably run that motor at 10-11*btdc.
Old Jun 25, 2005 | 11:20 AM
munrow's Avatar
munrow
Spend a couple more bucks for the timing light that just clips to the #1 wire. I think its called inductive.
redman84
17
May 29, 2013 12:38 PM
hughjazz
2004 - 2008 F150
Jun 25, 2012 11:42 AM
RANGER589
18
Jun 3, 2011 10:03 AM
dditto
Nov 7, 2008 07:57 AM
