Sponsored by: Innova
Wire Taps
Old Jun 24, 2005 | 03:51 PM
compfixerdude's Avatar
compfixerdude
Wire Taps
What is the best method and/or way ,product names would be good as well, to tap into wires that you dont want to cut?
Old Jun 25, 2005 | 12:10 AM
bill6302's Avatar
bill6302
the best method is to strip the insulation and solder the wire on then heatshrink it
Old Jun 25, 2005 | 07:12 AM
compfixerdude
How do you put on heatshrink if you dont cut the wire?
Old Jun 25, 2005 | 03:43 PM
E-150's Avatar
E-150
Bill6302 is right, soldering the connection is the best way. You can always just use black electrical tape to cover up the soldered connection.
If your looking for an easy way to connect a wire to another click HERE
I use these kinds of connectors.
What are you tring to connect to another wire? I ask this because you may start your car/truck on fire if you don't know what your doing.
Example: You want to connect something that draws 40 amps, you find a 18 gauge wire but for whatever reason it's not fused. Two problems with this, first never splice into a 18 gauge wire or use 18 gauge wire with 40 amps and always use a fuse. Anyway if this would be done, the wire would heat up and could cause a fire, park your car inside an attached garage and... you get the idea. Now this is just an example but you need to make sure the wire your splicing into can handle whatever your connecting to it.
Hope this helps.
Old Jun 25, 2005 | 03:46 PM
compfixerdude
Thanks for the info. I'm about to install a complete audio system with a remote start alarm. I have used the items that you sent in the link but was not sure if technology has changed in the last five years.
Old Jun 25, 2005 | 04:51 PM
E-150's Avatar
E-150
Yeah connectors haven't really changed, they may look cooler but serves the same task. I have an alarm on my deck too, but mine makes the speakers BLAST lol. With the deck just connect it to your radio harness, radio shack sells the adapter, just connect the wires from your radio to the harness and plug it in, no cutting. With an amp it's best to get an amp kit that handles the amps/watts your amp is. All wiring is included.
Old Jun 26, 2005 | 11:39 AM
vrsc's Avatar
vrsc
I have used the 3M type that E150 provided link for. They work really good but are a bit hard to close and snap at times.
Old Jun 27, 2005 | 07:55 AM
E-150's Avatar
E-150
Hey vrsc, I just use pliers or vice grips. Just crimp down the metal whatever you call it with the pliers and then just click the protector down.
Epd444
2009 - 2014 F150
Aug 13, 2014 06:52 PM
bronco slim
Mar 16, 2009 06:25 AM
ech0sh4y
2004 - 2008 F150
Nov 12, 2007 08:01 PM
hink10
Electrical Systems/Wiring
Aug 6, 2005 08:02 PM
partsetal
Nov 23, 2004 07:14 AM
