are you looking to put the 95 stuff into the 85 rig? if so then you will need the complete motor,entire engine harness, computer, fuel tank, fuel lines. radiator i think thats it
The '85 might not have provision for a knock sensor used in the '95 truck. Other than that, everything should work, just double check your firing order.
