does anyone have the conversion for an '82 axle code 14 it is obviously a 9" but seems high geared I have an '85 owners manual that lists the code as 3.00. could that be right?
Thank you sounds like a consistant number then looks like I have lots of options for gearing down for larger tires. 33's now are a bit much, but the ol' 300 pulls em pretty good this is a project truck that I just bought runs and drives, clean straight body bronco black and silver w/ 4spd can't wait to tear it all apart, big plans, lots of Ideas.
I've got an '85 F-150, and I want to go the other way, back to stock tires and a conversion to a little diesel. I have 4.11's, the rear with a limited-slip, and I'd be willing to trade you straight across, if you're interested. Thanks!
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
