Sponsored by: Auxito
Just Died
Old Jun 23, 2005 | 01:13 AM
vdm1245's Avatar
vdm1245
Just Died
I have a 2001 F150 Supercrew. While i stopped at a gas station it seemed well enough. Then, as i was starting the ignition to leave there was a click right before it turned over. All power died at that point. There is a relay located in the fuse panel (battery saver relay) that is clicking like crazy and is hot to the touch. I tried removing it and putting it back in. After several attempts at this ....the most i was able to achieve was to get the power back on for a sec or so.....and then it would die again. I found a similar story in another online article which leads me to believe this is not an isolated incident. Any assistance would be greatly appreciated. Thanks
Old Jun 23, 2005 | 06:22 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 23, 2005 | 10:32 AM
retired2001's Avatar
retired2001
My '02 S'crew's battery died last week with very little warning. It didn't make any "click" other than what you would expect from a low battery. It is already getting "HOT" here in the Hill Country and that is hard on batteries. Mine lasted for 87000 miles, so I guess it was due. Good luck on your's!
Old Jun 24, 2005 | 08:36 AM
spikedog's Avatar
spikedog
I would think the battery life would be based on age rather than mileage. Most of them come with 5 year warranties. But hey, if it went out, so be it.
VDM1245 - welcome to FTE. How did you get out of the gas station? Obviously you made it to a computer. I'm not familiar with a battery saver relay. Can you check the voltage from the battery to see how close it is to 12 volts?
Old Jun 24, 2005 | 08:51 AM
projectSHO89's Avatar
projectSHO89
Batteries can die at any time, regardless of age or mileage.
In this case, it would be best to first check the integrity of the battery and the primary battery cables and connections. I would be most suspicious of the negative cable.
If it was raining or you had just washed the truck, I might be suspicious of water leaking into the GEM module due to a windshield leak. However, since you indicated that ALL power was lost, I will accept that as fact and point you back to the primary battery cables.
Steve
unclegus
Oct 31, 2014 07:12 PM
Powerstrokin7.3L
Oct 10, 2012 06:47 PM
89ford73
Oct 11, 2011 05:12 PM
P1ckup Man
19
Jan 15, 2010 10:23 AM
Hiflyer746
Mar 8, 2009 05:46 PM
