Brake Dust
Old 08-18-1999, 08:17 AM
linder
Guest
Posts: n/a
Brake Dust
Lately I've been noticing a lot of brake dust on my front right rim on my 85 F150. All other rims are fine but the front right is constantly full of brake dust. Two other things I've notice too is that my brake pedal doesn't depress smoothly (it doesn't pulsate), and at high speeds, the truck sometimes vibrates. Any suggestions on where to look first?
Old 08-18-1999, 09:38 AM
Kyle's Avatar
Kyle
Kyle is offline
Brake Dust
My 96 F-150 is doing the exact same thing. I get a wierd vibration when applying the brakes at high speeds, except mine will pull to the right once in a great while, very inconsistant. My front end ( 2WD ) is overdue to have the bearings repacked, not sure if that will help the vibration or not. I will let you know.
Old 08-18-1999, 01:07 PM
Phillip Guidry's Avatar
Phillip Guidry
Phillip Guidry is offline
Brake Dust
Excessive brake dust only on one wheel,if both wheels have identical brand/quality pads,is more likely caused by a sticking caliper piston on that side.After a drive,very carefully feel the wheel of both sides to measure a temperature difference.The suspected wheel will be much hotter to the touch if the caliper is sticking.The vibration you experience could be from a warped rotor caused by the excessive heat of the brakes.The increased pedal effort could be related to the sticking caliper as not only will the piston not release,it will not apply easily either.
Phillip
Old 08-18-1999, 06:55 PM
murf's Avatar
murf
murf is offline
Brake Dust
stupid red ranger
1983 - 2012 Ranger & B-Series
20
04-21-2016 08:24 PM
boatnfish
2009 - 2014 F150
25
03-04-2012 09:20 AM
Icefan71
1997-2006 Expedition & Navigator
11-23-2009 07:14 AM
thinksnow
1999 to 2016 Super Duty
11-26-2008 04:53 PM
gregarobinson
2004 - 2008 F150
22
09-06-2004 10:54 PM
Quick Reply: Brake Dust
