I have a quick question. My Tranny is leaking fluid from what looks like the rear seal plate. It is the plate that is basically bolted to the tranny crossmember. Also it has about a dozen 15mm bolts in it. Is there a gasket back there? Do I have to empty all the fluid out to change the gasket? Any advice would be appreciated. By the way where would I be able to buy this gasket? Thanks....
