does 97 rear tank fit 91 ?
A few years ago I put a front diesel tank out of a '97 F-350 into my '89 150. Dimensionally the tanks were the same, but the hole for the sending unit/low pressure pump was a little different. It's been a few years since I did it, but I think I had to bend the locating tab for the sender on the diesel tank so I could put the gasoline sender in the correct position. A little extra (and unexpected) work, but it's still holding gasoline.
The rear tank you have will most likely fit right in, but expect a few bumps in your road in regards to the sending unit.
HTH
Pat
HTH
Pat
F250FarmBoy
13
10-25-2019 04:51 PM
vmk
06-21-2005 11:51 AM
