Mildew Smelling A/C
Old Jun 22, 2005 | 12:36 AM
Desert-Rat's Avatar
Desert-Rat
Unhappy Mildew Smelling A/C
04 E-350 15 pass van has a meldew smell when using the max a/c. kinda smells like wet cement after a rain. anyways, a friend of mine told me to spray some disenfectant in to the air circulation intake area between the hood and the windshield. well this took the smell away for about a day, it is back again. I want to get rid of it forever... Any suggestions?
Old Jun 22, 2005 | 12:54 AM
pfogle's Avatar
pfogle
Spray bleach into it. The bleach will kill the mold that's causing the smell. The other alternative is to tear it all apart and clean it out by hand.
Old Jun 22, 2005 | 08:08 AM
goofy173's Avatar
goofy173
After the bleach you may want to spray a mixture of water and baking powder or you may smell that bleach for a long time.
Old Jun 22, 2005 | 03:03 PM
tdister's Avatar
tdister
I've found Ozium to work really well for this. Turn the a/c to max (recirculate) and spray into the intake uder the dash. Give another good spray in the air before closing the door and letting it run a few minutes. The food source (dust/hair and the like) of the smell is still there though, so this will need repeating once in a while. I usually do this when I vacuum/clean the interior once a month or so.
Turning off the A/C a few minutes before it's parked will help dry out the evaporator and stop some of the source of the smell (that's what I hear anyway).
Bleach sure seems like it would work. What ratio?
