4bbl on 240?
Old Dec 22, 2003 | 02:14 PM
charliemccraney's Avatar
charliemccraney
4bbl on 240?
How will a 4bbl perform on a '74 E100 with a 240ci I6? I am looking at the offenhauser dual port 4bbl manifold and 390cfm vacuum secondaries holley. Does anyone know what the cfm rating of the stock 1bbl is?
Old Dec 22, 2003 | 02:15 PM
charliemccraney
Oh. Headers may be used but the rest of the engine will be stock.
Old Dec 23, 2003 | 04:40 PM
pfogle's Avatar
pfogle
You will notice a difference, good luck and let us know how it goes.
Old Dec 24, 2003 | 07:36 AM
charliemccraney
My main concern is low-end torque. I want to improve or at least maintain low-end torque while increasing high end power. I know that bigger usually means low-end loss and mid to high-end gain but the design of the offenhauser manifold looks like it may be able to provide a little of both worlds. Maybe even better fuel mileage.
Old Jun 23, 2005 | 01:08 AM
snotwilim's Avatar
snotwilim
If the primary barrels aren't too big, your low end shouldn't suffer that bad. I'm sure you have to do quite a bit of adjusting on that carb to keep it from bogging when the secondaries open up. I don't see how a 240 could pull that much air without stumbling a bit.
David Moran
20
Nov 7, 2014 11:06 AM
76oleblue
May 9, 2008 12:36 PM
southernford
Dec 29, 2001 05:57 AM
