General Automotive Discussion
Rust on dip stick.
Old Jun 21, 2005 | 09:43 PM
oricle's Avatar
oricle
Rust on dip stick.
Well I was changing my oil, and went to pull the dip stick out after I filled it back up, and saw it was rusted. Wiped my dip stick off, and put it back in and saw rusty crud sitting on the bottom of the dip stick...
Does it sound like for some reason I have a leaking gasket thats allowing water in?
Old Jun 21, 2005 | 11:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
Make sure your PCV valve is operating properly. Short trip driving will also cause water to condense in various cooler parts of the engine.
Old Jun 22, 2005 | 12:39 AM
oricle's Avatar
oricle
how would i make sure the pcv valve is working ok?
Old Jun 22, 2005 | 05:23 AM
Marcus6679's Avatar
Marcus6679
When you remove it from the valve cover, shake it. If you hear something rattle inside, it's still working. They usually cost under $5, so if it isn't working, it won't set you back all that much.
Old Jun 22, 2005 | 07:40 AM
fred_79f250's Avatar
fred_79f250
I recall reading somewhere recently that rattling does not guarantee the pcv valve is working. I don't remember exactly where so I can't confirm that with a reference, but it might be worth looking into.
jcweis1
Mar 7, 2016 07:55 PM
Amicus
Jul 31, 2015 09:10 AM
schafer407
Sep 16, 2014 12:16 AM
rockpile
Mar 30, 2014 08:00 PM
tanman722001
Jan 10, 2013 07:50 PM
