Upper Intake Cleaning
Old Aug 27, 1999 | 08:51 AM
Bryan's Avatar
Bryan
Has anyone cleaned their upper intake on a 302EFI?
I was cleaning my throttle bores and noticed it looked gummed up in there. Is there a spray available like carb cleaner or is better to remove it and get right in there.
Bryan
Ontario,Canada
89 f150 Ext.Cab
Old Aug 27, 1999 | 10:48 AM
Phillip Guidry's Avatar
Phillip Guidry
There is a machine called "motor vac" that has a wand to insert into the intake and dispenses highly concentrated cleaner that will remove disolvable sludge.The machine also back flushes the fuel system and pressure cleans the injectors.It is beneficial to have this service performed.You will have to search for a shop that has this type of machine.
Phillip
Old Aug 27, 1999 | 06:16 PM
ray's Avatar
ray
You can do more harm than good by cleaning the TB area if you use the wrong cleaner. Some coatings can be softened or ruined. FWIW, ray
Old Aug 31, 1999 | 01:16 AM
Kyle's Avatar
Kyle
I wouldn't sweat it. If you have enough crud in there to make a difference with cleaning it, you got bigger problems to worry about. Gas milage and horsepower will actually go down if you do clean it. That thin layer of carbon inside the intake has a similar effect that porting and polishing has.
It is easy to take it on and off however. Watch the vacuum lines routed at the rear of the intake, and note recommended torque and torque sequence. I believe it is center out on the sequence, can't recall torque rating.
For the other fellas post, my 89 F-150 302 did not have teflon coatings on the throttle body. I believe that didn't happen for a year or two, and that may only be single tb's like the mustang and crown vic's. Either way, if you lose the teflon coating, you havent lost much. According to some, its actually a benefit to lose it.
Generally speaking, cleaning fuel injectors is "snake oil". May give you peace of mind, but its actually only neccessary if you have had contaminates in your fuel system that are dissolvable by the FI cleaner solvent. Remember injectors on EFI 302 motors run at about 40 psi or better, so not a whole lot of contaminates can get caught up in there.
Old Aug 31, 1999 | 08:05 AM
Phillip Guidry
douglpr42
New Member Introductions
Sep 7, 2008 08:41 PM
bryan_johnson
Jan 11, 2005 05:28 PM
bryan_johnson
Jun 2, 2002 11:07 AM
bp1959
Nov 21, 2000 01:19 PM
bryan_1
Oct 29, 1999 09:23 AM
