Replacing Small Driver Side Vent Window
Old Jun 21, 2005 | 04:20 PM
302FORDF100's Avatar
302FORDF100
Has Anyone Ever Had To Remove One Of The Two Small Vent Windows
On The Driver And Passenger Door. And If So Is It Hard To Do?
Old Jun 21, 2005 | 05:34 PM
Djoffroad's Avatar
Djoffroad
It is not complicated, but can be difficult.
Remove the door pannel and large window.
Remove the screws securing the wing window to the door frame.
remove the nuts holding the window track in place.
carefully work the wing window out. It's kind of a Hudini trick to get the window to slide all the way out with the track.
Old Jun 21, 2005 | 06:37 PM
bulrydr_1's Avatar
bulrydr_1
A Hayne's manual will also tell you where all those screws aree you need to remove. Like Djoffroad said, not complicated, but a bit difficult....By the way, you need to take out the entire frame for the wing window..don't try to remove ust the glass part itself...
Old Jun 23, 2005 | 10:48 PM
beeboy's Avatar
beeboy
you can also just remove the wing window assembly, and leave the track in place. That way you dont need to remove the main glass also.
Old Aug 1, 2005 | 09:44 AM
Blue Bear's Avatar
Blue Bear
Old Aug 1, 2005 | 10:50 AM
MBBFord's Avatar
MBBFord
Blue Bear, did you catch the as* who did that? I'd want to kill !!!
But the vent windows have their own bit of troubles, but open up time one morning and get started, and you should have it finished in a couple hours depending on how fast you do it.
Lloyd399
18
Jul 10, 2017 05:49 PM
weez440
WTB - Parts & other
Feb 18, 2011 06:34 AM
calvin42
Nov 11, 2008 01:56 AM
