HPOP Question
Old Jun 21, 2005 | 02:24 PM
fordf350crazy's Avatar
fordf350crazy
HPOP Question
Can anyone tell me where the HPOP is, and how to check the fluid level?
Old Jun 21, 2005 | 02:29 PM
Max1775's Avatar
Max1775
HPOP is at the top front of the engine, right in front of the fuel filter housing. There is an allen wrench style plug on the left side of the top of the housing that you remove. Oil level should be within 1" of the top. I'll try to find pics if you can't locate it.
Max
Old Jun 21, 2005 | 02:33 PM
fordf350crazy
Max,
If you have pics, that would be great. Is it hard to replace the O-rings? I think mine is leaking cause there is oil all around it, and I am getting a loss of power. What do you think?
ltfox's Avatar
ltfox
Right in front in the engine valley. You'll have to remove the top cover and then the top plug for the resivior is right their. Remove it with a 1/4 inch rachet. HPOP is right behind the resivior.
Old Jun 21, 2005 | 03:32 PM
Max1775's Avatar
Max1775
Here's a picture of the reservoir (after hte powerstroke cover is removed)and one of the HPOP lines (the one with the red mark on it. The o-rings are pretty easy to replace, only takes a little patience.
Old Jun 21, 2005 | 03:49 PM
fordf350crazy
Thanks Max!
