Brake shimmy
Old Jun 21, 2005 | 02:08 AM
ACE81's Avatar
ACE81
Brake shimmy
I have a 1995 F-150 Eddie Bauer edition. I was a having a bad shimmy in the steering wheel when applying the brakes. So the rotors and pads were replaced in December 2004. In March 2005, the shimmy returned. I went back to the shop and they replaced the rotors, no charge. Now in June 2005, I have the shimmy again. It seems to happen when applying the brakes when going between 40 and 50 MPH. I have had no hard braking or driven through any deep water. Also the brakes have started pulling to the right. Any ideas?
Thanks,
David
Old Jun 21, 2005 | 02:18 AM
Gregstopspeed59's Avatar
Gregstopspeed59
I have a 91 f150 w/ the same problem. Could this be a caliper issue, I think it is just the front brakes?
Old Jun 21, 2005 | 02:56 AM
pfogle's Avatar
pfogle
Try changing the calipers and hoses on the front. What kind of pads did the install? I'd use either the bendix titanium metallic, or a good ceramic pad. These will help the stopping distance, reduce dust, and help with wear. It sounds like they may be using cheap rotors.
Old Jun 21, 2005 | 09:47 PM
Cobra-Master's Avatar
Cobra-Master
My 95 F150 does the same thing... subscribing...
Old Jun 21, 2005 | 09:52 PM
1987F-150's Avatar
1987F-150
Just had the front brakes on my 87 F-150 redone for a similar problem. Started with a shimy when braking and ended up with a caliper locking up. Turns out one of the front brake hoses was going bad and not letting the caliper piston retract. Id check the hoses and the calipers.
