302 for 302 swap question
Old Jun 21, 2005 | 12:50 AM
durk's Avatar
durk
i was in need of a new engine for my car and i came upon a 302 motor that has roller lifters in it. so i looked up the casting #'s and it seems to be out of a truck. so thats why i am here. First off, will this motor take the stock parts off of a carb motor? (manifold, water pump, etc.) and is this a roller motor? i am going to rebuild it no matter what, I just need to know what parts to order when I go to order them. do i need a roller cam or can i get a stock cam for a 65 falcon? and what cam will the roller lifters work with? as you can tell i know nothing about the "small block" Ford engines, i like the FE's. any help will be greatly appreciated. thanks, Chad
Old Jun 21, 2005 | 09:39 AM
Kemicalburns's Avatar
Kemicalburns
go to barnes and noble an get the smallblock fords performance book. it will give you all the in's & out's. you would have to use the timing cover off your old 302 along with your intake and of course change out dizzy . i would call compcam about what cam to run in your setup dont run a used cam.
Old Jun 21, 2005 | 10:33 AM
durk's Avatar
durk
i wasn't i'm just trying to figure this thing out. as i inspected the block more i found that the bottom of the #8 cylinder wall has been broken. i call the machine shop and told him and he said he could put in a sleeve or he may be able to "cut out" the bottoms of the cylinder like he would if i were putting in a stroker crank. i know this can be done with a chevy to make a 383, but i have never heard of it being done to a ford. is this possible because if it is I may go build a stroker. so once again thanks for all the help. Chad
Old Jun 21, 2005 | 02:00 PM
ronclark's Avatar
ronclark
You can fix but why? 302 blocks are easy to find and probably cheaper than having the machine shop fix the bad one.
Busted Bones
Jan 18, 2017 10:57 PM
Anthonynoble
Jul 12, 2015 08:33 PM
71f100s
16
Oct 1, 2014 12:48 PM
Jordanz_03
Nov 6, 2012 09:00 AM
Kruse
Sep 15, 2010 07:43 PM
