Ultimate Cooty-Bob contest?
Old Jun 20, 2005 | 02:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I enjoyed the "dumbest thing I ever did" thread, and I just came across a striking example of cooty-bob'ing by the PO (previous owner). Thought I would throw it out, see what other "backyard engineering" is out there.
I purchased a set of clutch shaft bushings a long time ago, just because they were cheap and I figured they'd be needed sooner or later. The clutch actually worked pretty smoothly, replacing the bushings wasn't high on my list. But today I had to pull the shaft to route a new fuel line along the frame. When I started degreasing it, my first thought was, Oh crap, it's not like the one in the manual. Instead of two bronze bushings, a piece of steel fell out. After all was clean, I realized the PO had put a piece of hose clamp in the socket to replace the totally worn out bushings! Left to right, new bushings, what's left of the old bushings, and the hose clamp.
Anxiously awaiting your stories!
Old Jun 20, 2005 | 03:14 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I don't have the pictures of it, but the PO of my truck had done some interesting "updates" to the rear suspension. On one side of the truck the pins for the leaf spring were completely gone, in their place was a 5/8" bolts. the only thing that kept them from falling out were the flanges on the bed side where they hang down below the spring hangars. The shock mounts were very similar
But check out the following picture of the current owners set-up. I might add that this was all temporary so I could fire the engine and drive it around the block to check power brakes, steering, etc. Note: the PVC upper radiator hose, and the DOT approved fuel tank, not to mention the lovely heater hose. All of these have since been removed and taken care of...........lol
Old Jun 20, 2005 | 10:28 PM
husker's Avatar
husker
I loved the pictures and the "engine"new-ity in both. Did the truck drive ok with the special setup? lol.
Del
Old Jun 21, 2005 | 09:53 AM
bobbytnm's Avatar
bobbytnm
I drove it around the block a couple of times, enough to get the neighbors attention (did I mention that the exhaust was only 6" long at the time?) I have updated a few things since then. I now have a real fuel tank residing between the frame in the rear and I will fabricate an upper radiator hose assy as soon as I can stuff tha big Caddy back into the truck (hopefully within the next few weeks)
Bobby
The Horvaths
15
Dec 29, 2013 06:42 PM
bobj49f2
24
Apr 29, 2009 10:17 PM
Glockem45
19
Apr 11, 2009 05:11 PM
ALBUQ F-1
23
Apr 2, 2009 02:14 PM
frederic
16
Oct 31, 2005 01:51 PM
