Timing Gears or Chain
Old Sep 12, 1999 | 11:34 AM
Pastmaster's Avatar
Pastmaster
I was curious whether a 1989 302 would have a Timing chain or Gears. I am about 90% sure its got a Chain. The truck has 128k on it. If it has a chain then its probably needing replacement. When does the gears need replacement? Can you replace Chains with the gears?
Old Sep 12, 1999 | 02:34 PM
ray's Avatar
ray
The '89 302 will have a roller chain. If the truck has been serviced regularly the chain may be in decent shape. The roller chains last a lot better than the old plane tooth type chain. At 100K the old chains were history. fwiw, ray
Old Sep 12, 1999 | 05:58 PM
Pastmaster's Avatar
Pastmaster
>fwiw, ray
How can you tell if the chain needs replacement? Does a 1993 have the same roller chain?
Old Sep 13, 1999 | 06:13 AM
Deen Hylton
Guest
Posts: n/a
Always replace timing chains and gears as a set. At over 100k miles I'm sure there is enough chain stretch to effect timing (which will rob HP and MPG). Cost is under a $100.
Old Sep 13, 1999 | 08:29 AM
Phillip Guidry's Avatar
Phillip Guidry
