F150 Towing
Old Sep 13, 1999 | 08:38 AM
macalow's Avatar
macalow
F150 Towing
I have a 1985 F150 4wd 351W with a C6 tranny and 3.00:1 axle ratio. Has anyone used this set up to tow 6,000# at highway speeds. If it didn't work out would you change the axle ratio or transmission.
Old Sep 13, 1999 | 09:14 AM
Reuel's Avatar
Reuel
F150 Towing
I have not used this exact setup but it sounds to me like the load is a little heavy. If i were doing this i would at the least change the gear ratio to high 3's or 4.11. Depending on how far and how often you are towing and if you live in hilly country then i believe your current setup will be very taxing at best. You will have to wiegh the performance issues if this is your everyday driving truck. Once you change the gearing for towing then your normal driving performance will not be as good as present.
Old Sep 13, 1999 | 11:34 AM
slik's Avatar
slik
F150 Towing
pecanguy
Aug 19, 2013 07:55 PM
PennaLonghunter
2004 - 2008 F150
Aug 28, 2010 06:38 AM
Templer
2004 - 2008 F150
Oct 27, 2003 11:48 PM
teederj2002
13
May 16, 2003 11:58 AM
ol_geezer
Feb 22, 2003 09:41 AM
