Atten: Moe or Slik
Old Sep 13, 1999 | 09:08 AM
Reuel's Avatar
Reuel
Atten: Moe or Slik
I have a 1984 F-150 with a 302, AOD Metric trans. I want to replace the engine with a 351W. Can you give me a quick run down on the mismatches I will encounter? Like the timing cover, intake man, exaust man, distributor, bell housing etc. I have done engine swaps before but i would like to be a little more prepared this time around. Thanks.
Old Sep 13, 1999 | 11:34 AM
slik's Avatar
slik
Atten: Moe or Slik
I'm not sure what an AOD Metric is, but the bell housings should match. The measurement between the top two bolts on your housing should measure 5 1/4". I think you will need, new harmonic balancer, new flex plate (rebalanced), new timing cover, new intake, don't know about exhaust, and I think you will need a different oil pan. You can use the rest of your front mounted accessories (Alt, A/C, power steering, etc.) with the purchase of an adapter from Ford. Everything else should bolt right up!
Slik
Old Sep 13, 1999 | 02:35 PM
Reuel's Avatar
Reuel
Atten: Moe or Slik
