1986 F150, Ignition problems
Old Sep 16, 1999 | 11:05 PM
Superdave's Avatar
Superdave
Old Sep 17, 1999 | 05:49 PM
Bill's Avatar
Bill
4.9 LT., stand.,carb.,TFI, Which sensors, if bad will cause "no spark"?? What equipment is needed to test the engine sensors??
Old Sep 17, 1999 | 07:45 PM
Bent6's Avatar
Bent6
I don't think any sensor will cause a no spark condition. Most likely you problem is in the pick-up coil or igniton module(TFI). My steps to diagnose a no start:
1: Using a 12v test light, probe the negative side of the coil while someone cranks the car/truck. The test light should blink. If it blinks, check the coil with an ohm meter and compair to service manual values. Don't forget to check the simple stuff like plugs/wires.
2: If it doesn't blink. Pull the coil wire and hold it over ground. Have the person inside the car turn the car to run then off. There should be a single spark. If you get a single spark the problem is in the pick-up coil. If there is no spark the ignition module is likely be bad.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
1978 - 1996 Big Bronco
May 25, 2002 03:08 PM
broom
Nov 24, 2001 12:46 PM
