front end problem?
Old Jun 19, 2005 | 11:12 AM
SLisk7's Avatar
SLisk7
front end problem?
truck has play in the steering and is all over the road. Every time i hit a bump it really throws you. Anyone have any idea what the problem is? Is this a problem in these years? thanks
Old Jun 19, 2005 | 11:15 AM
Chevy_Eater's Avatar
Chevy_Eater
In what year?
Check your steering coupler.
Old Jun 19, 2005 | 11:16 AM
SLisk7's Avatar
SLisk7
Originally Posted by Chevy_Eater
In what year?
its a 1986 f250 diesel 6.9
Old Jun 19, 2005 | 11:18 AM
SLisk7's Avatar
SLisk7
also i have relplaced tie rods and it wasn't that
Old Jun 19, 2005 | 11:33 AM
Chevy_Eater
The steering coupler is the gizmo that connects your steering column to the gearbox. Unfortunately in these years they sell you the whole lower shaft (pricey), unlike older Fords where it’s just a $12 rubber bushing.
Old Jun 19, 2005 | 12:35 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Ball joints or steering coupler.
Could also be the bushings on the axle pivot points where it attaches to the frame.
My 86 has over 300,000 on the clock and drives like a new one.
Old Jun 19, 2005 | 08:19 PM
Pigeon's Avatar
Pigeon
did you check your drag link and connecting rod joints when you did your tie rods?
Old Jun 19, 2005 | 08:42 PM
Marcus6679's Avatar
Marcus6679
To check what is causing the problem, jack up the front of the truck one wheel at a time. If there is significant play when you push and pull on the 9 and 3 o clock positions, steering linkage is the culprit. If there is excess movement when you push and pull at the 11 and 5 o clock positions (right side) or 1 and 7 o clock positions (left side), bad ball joints are the cause. Wheel bearings can be checked at the 12 and 6 o clock positions. I know that some of the older Ford pickups had a problem with the link arm between the left and right steering knuckles, if you grab the shaft and it is easy to flop it back and forth, the rod ends can be adjusted at opposing angles to lock themselves into place.
Old Jun 20, 2005 | 09:06 PM
SLisk7's Avatar
SLisk7
thanks alot guys......ill let you know how everything goes
Old Jun 20, 2005 | 09:29 PM
SLisk7's Avatar
SLisk7
also dont think its the bushings, the guy that had it b4 me replaced them with new polyurethane ones
