tow package on 04
Old Jun 19, 2005 | 01:21 AM
adsacu's Avatar
adsacu
tow package on 04
What equipment is part of the tow packege? the manual say if equipt i am not sure what that means.
Old Jun 19, 2005 | 07:57 PM
jakermc's Avatar
jakermc
Look through your front grill, if you have 2 small coolers in front of the large radiator you have the HD tow package. One is a tranny cooler, the other cools the power steering (I think). I am fairly certain that the existence of a 7 pin connector next to the hitch is also another way to verify. I think w/o the factory tow package all you have is a four pin connection. You also get the higher ratio on the rear axle.
Old Jun 19, 2005 | 08:12 PM
ford390gashog's Avatar
ford390gashog
it will have the 5.4 engine tranny cooler,bigger radiator, 7 pin plug and 9.75 rear axle with 3.73 ls diff.
Old Jun 22, 2005 | 12:56 PM
powderhounder's Avatar
powderhounder
They all have the 5.4L engine now, so you can't go by that.
Old Jun 22, 2005 | 01:43 PM
TDN's Avatar
TDN
According to the 04 order guide, the only option required for the Tow Package was the 5.4L engine. The package included 7-pin wire harness, heavy duty auxiliary transmission oil cooler, heavy duty radiator (mid-year production change as of 12/1/03), electronic braking wiring kit, and upgraded the trailer hitch receiver from Class III to Class IV. You could have either the open diff (with or without AdvanceTrac) or LS diff.
I would agree that the 7-pin wire harness is the easiest way to tell, as long as the truck hasn't had any aftermarket mods.
WIKD
Oct 19, 2010 07:59 PM
D-mon
1983 - 2012 Ranger & B-Series
19
Aug 10, 2009 02:30 AM
MobeyDick
Sep 6, 2005 02:39 AM
cjr
2004 - 2008 F150
Aug 9, 2005 09:52 AM
jschira
All Things Towing
Jan 14, 2003 10:45 PM
