Losing Coolant
Old Sep 26, 1999 | 03:24 PM
Hdlinerman
Guest
Posts: n/a
Losing Coolant
Here I go again, 1988 F150 XLT/Lariat with 300/i6 and 5 speed tranny. I have been losing coolant since I have had this vehicle (14 mos.). I had the cooling system pressure tested and everything was fine. Noticed signs of coolant coming out of the top of my overflow jug. Pressure tested radiator cap and it would not hold pressure. I thought great this is my problem and replaced the cap. Still to no avail, I am still having to add water/coolant every 3 days. I noticed my front freeze plugs showing signs of leakage. Could this be my culprit or is it something else? Again, any help will be greatly appreciated. This truck has 145,000 miles on it. Other than the loss of coolant, exhaust leak, and tranny woes, it is in great shape and need it to last another 145,000 miles. HELP!!!
Old Sep 27, 1999 | 01:19 AM
Superdave's Avatar
Superdave
Losing Coolant
you will need to eliminate the obvious leaks first before you look deeper
Old Sep 27, 1999 | 09:41 AM
nissanjon's Avatar
nissanjon
Losing Coolant
i had a couple of freeze pulgs rust out on me. it was just a constant drip, until one night, in the middle of nowhere, they completely opened up, and all the coolant drained!
that sucked.
anyway, get the freeze plugs checked. i was told that rusted-out freeze plugs can be common.
Old Sep 28, 1999 | 05:33 AM
hdlinerman
Guest
Posts: n/a
Losing Coolant
>miles. HELP!!!
Could there be pressure building up and blowing it out of my overflow container while I am driving?
Old Sep 29, 1999 | 12:09 AM
Superdave's Avatar
Superdave
Losing Coolant
Hdlinerman, your coolant recovery tank isn't full is it? there is a line on the tank to fill it to.make sure the hose running from the radiator is all the way down in it. and your coolant could leak from the freeze plugs under pressure also. a tight seal on the radiator cap is important ,so the coolant can transfer back and forth from the recovery tank to the radiator, if you can see the freeze plugs leaking like you said I'd replace them then see what happens then. good luck.
Old Sep 29, 1999 | 04:20 AM
Hdlinerman
Guest
Posts: n/a
Losing Coolant
When I fill the recovery tank, I never add more to it than the line that you mentioned. And as far as I can tell, there is a tight seal with the cap and the tank. For the freeze plugs, I have never seen them actually leaking, the block is stained right below them as if they had been leaking. After driving the truck any distance, I can park the vehicle and there is no evidence of fluid being on the ground below the engine compartment. Another theory I had not wanted to think is if I could be loosing it through my intake/exhaust ports, i.e.; blown head gaskets. I do have an exhaust leak at the manifold. I'm wondering if this has anything to do with this?
Old Sep 29, 1999 | 08:03 AM
Phillip Guidry's Avatar
Phillip Guidry
Losing Coolant
You may be losing some through the heater core or hoses leading to it.Turn on the heater to high and full hot and smell a little bit.Most busted heater cores will drain the coolant through the same drain as for the A/C evaperator.
Phillip
Old Sep 29, 1999 | 08:07 PM
Kevin's Avatar
Kevin
Losing Coolant
Have you accomplished a compression check? It may just be a head gasket going bad and your coolant is going up in smoke. With 145,000 miles on it, it is a possibility. I would think that if you had a leak bad enough to have to add coolant every three days you would have seen something on the ground by now. Good luck to you.
Old Sep 30, 1999 | 05:18 PM
H8monday's Avatar
H8monday
Losing Coolant
