Idle problems
Old Sep 29, 1999 | 10:40 PM
joe_1's Avatar
joe_1
Idle problems
1990 F250 4x4 460 , 3 spd auto,air, cruise. Seems to idle a little slower than usual..5-600,But when put in R or D, the idle jumps up strongly to about 700 and the truck tries to take off suddenly. when shifting back to P or N, it drops off dramatically, and sometimes will die before evening out. The difference is still there with the AC on, but not quite as noticeable.Any ideas? Thank you very much.
Old Sep 30, 1999 | 07:43 AM
Phillip Guidry's Avatar
Phillip Guidry
Idle problems
I think the problem is a vacuum leak.The computer will try to maintain idle according to load on engine,making erratic adjustments when you drop it in gear and out of gear.Startt by checking the vacuum line at the trans. modulator.Then all the ones in the engine bay including the PCV valve.Refer to the emissions decal for vacuum diagram.
Phillip
Old Sep 30, 1999 | 10:47 PM
Joe's Avatar
Joe
Idle problems
Thank you for the tips, I'll trace evry line and check them out. After thinking about it, that makes alot of sense to me. Thanks again for your help.
Old Oct 1, 1999 | 06:48 AM
Charla
Guest
Posts: n/a
Idle problems
