need info on 01 4wd system
thank you!
thank you!
does this system use vaccum?
I wanted the manual shift but I got a killer deal on the Lariat. Now Im just afraid if something did go wrong it would be costly, but 4 years and no problems.
ok here is my dilemma, have 01 with auto , has 250000 miles on it, did rt front bearing about 15000 miles ago, started hearing weird noise about a month or 2 ago took it to the dealer twice they cannot find what it is, keep driving moise stays the same, like a metal on metal sound for just a second when going over a bump, well it finally broke on the highway, big grinding sound then go over a bump, fine
anyway axle on that side is trashed, seal gone where it hooks to bearing so it tore up bearing too even though it turns fine
in the process of all this i hear that the auto hubs can stick and burn up the bearing and axle, i am like what???? i don't really know what it would feel like if it is sticking and i am 70 % deaf so might not hear it, well get bearing and axle back on and am paranoid about hubs sticking now so make shop check them, although i understand that it can happen intermitently
well the right hub is original or is at least stamped 01, it seems to be working fine but the left one is stuck turning even though i pulled and plugged vaccuum lines , icannot get it to let loose even manually, i have no idea how long it has been like this
i do a lot of highway driving but do use my 4wd at least a couple times a month in mud or sand
if i got 250000 out of this last set of autos then i don't mind putting them back in, of course i don't know that they haven't been sticking?????/ i don't know what to do and i don't even knwo if i can get a manual set here and my work truck has been down 4 days already!
on diesel stop these guys are saying that they run with their hubs locked all winter and have no prob, BUT these are not the same system as mine, older trucks
the more i ask about this system , the more different answers i get as to how it functions
need input on what manuals are avilable and what is better, etc
thanks for your time!
Now....here's what I suspect happened. If the hub was wearing out....it would cause the wheel,tire,rotor...all to lean from side to side. This unwanted "slop" would cause the stub axle to bind, along with causing unwanted stress on the rest of the drive axle assembly. I would guess that the friction that would be produced could cause heat and seal failure. This would also cause a grinding sound as the disc rotor, bearing race, desintigrating bearing all contacted things they shouldn't. That's the only way that I see for this to happen. Hope this helps.
