melted windsor pistons
Old Jun 28, 2005 | 06:50 PM
  #31
78with38s's Avatar
78with38s
well i wedged the carb. spacer plate, widened my top ring to .22 clearance and won the heat and feature, everything is working great so far. thanks.
Old Jun 28, 2005 | 06:57 PM
  #32
220k-f-150's Avatar
220k-f-150
Congrats. I always like to see the Ford win.
Old Jun 30, 2005 | 01:03 PM
  #33
MustangGT221's Avatar
MustangGT221
Glad to hear everything is working out!
Old Jul 2, 2005 | 10:58 PM
  #34
PyroBandito's Avatar
PyroBandito
Originally Posted by wildjon300ci
If too small of a ring gap...the rings would have butted, siezing up in the bore ans breaking off the piston skirt and ruining the cylinder wall. I'm willing to put money that he's running lean. maybe a blockage in the intake? Bad carb tune? Not enough fuel pressure?
Correct me if i'm wrong, but a blockage in the intake causes a rich condition, not lean, right?
Old Jul 4, 2005 | 01:53 PM
  #35
MustangGT221
Well, if there is a blockage in the intake of a carbed engine, fuel and air will both be restricted since...they're both flowing through the intake. I would think a blockage could make it run rich or lean...
Old Jul 5, 2005 | 12:53 AM
  #36
PyroBandito
yeah, you're right about that, that's a different problem than what i was thinking of. I don't have a carb on my engine, so I'm not familiar with them. I was thinking of a blockage above the jets, causing choking, but thats just cause I work on lawn mowers all the time, lol. I know in a fuel injected engine, if you have a blockage in the upper intake, it causes a rich condition, that's where I got it from. Thanks for clearing that up for me.
Old Jul 5, 2005 | 10:34 AM
  #37
MustangGT221
It causes a rich condition because the fuel injectors are down by the end of the intake port, right before the cylinder head. There is no fuel traveling through the manifold, just air. So the blockage would only block air...lowering the amount of air vs fuel...causing rich condition.
Lawrence Taylor
13
Jul 7, 2014 09:44 PM
FarmerFrank
Nov 21, 2012 07:53 PM
Needsoles
May 24, 2009 02:46 PM
tdg351w
Jun 11, 2004 11:02 AM
scup
15
Mar 15, 2002 10:13 AM
