Is MDS the future for big V-8s? Chrysler thinks so
Dodge is going to offer Multivalve Displacement Systems in its Hemi engines in the new '06 Ram Pickup...in fact the entire Hemi engine line will have MDS, which shuts down valves when less power is needed increasing fuel economy.
Is this the future for V-8s? Isn't Ford supposedly working on something similar?
That Caddy system was absolute junk. One of the worst ideas in the history of internal combustion engines.
But now that we have sequential port fuel injection and ECU's that control hundreds of different engine parameters, things are totally different.
I do have reservations about the use of such a system in trucks, however, especially where heavy loads or towing is involved. A system that shut down cylinders under a "light load" situation, might not work so well with trucks carrying close to max payloads or pulling trailers close to maximum gross weight.
I never understood the theory behind this. You've still got all the internal friction you had before. Plus, the remaining working cylinders are now working harder. You decrease fuel vaporization by decreasing manifold vacuum. Yes, it's fuel injection, but manifold vacuum still has an effect. They should be focusing on something like variable valve timing, which WILL help. And I dont mean just advancing / retarding the cam with rpm, I'm talking about changing lift and duration with rpm and load. There are ways to do this. At low engine loads, reduce the duration and lift, close the intake valve earlier to build more compression, run it lean, and advance the timing. Duh.
Personally, I think the whole cylinder shutdown idea at low engine load is stupid. Note, I didn't say that about anyone on here. Just about the idea from the vehicle manufacturers. I am not calling anyone on here stupid.
Originally Posted by Armada
That Caddy system was absolute junk. One of the worst ideas in the history of internal combustion engines. But now that we have sequential port fuel injection and ECU's that control hundreds of different engine parameters, things are totally different.
It is a good idea but took modern day electronics to make it function better than the old Caddy system did.
Originally Posted by Monsta
DUH? You make it sound as if the technology is available at the grocery store! If it is that easy it would be in effect now. Currently only F-1 car engines have that pneumatic valve technology. Do a search on camless valve actuation, too. Both are coming to production engines but not for a while.
Originally Posted by captchas
it's in the jeep hemi right now and seems to be working.
While jeeps site isn't very clear, from what I've found, no. The hemi is the top in towing at 7k+ lbs. From what I understand it only activates under 2K RPM's and only at low constant throttle. Not gonna happen while towing anything substantial.
Anybody have a good site explaining the MDS?
Supposedly GM is coming with a near identical version soon.
Originally Posted by 1956MarkII
1) Sneak up behind a long-time Cadillac dealer and yell, "VEE-EIGHT-SIX-FOUR IN THE SHOP!!"
2) Call the paramedics and tell 'em to bring the paddles...
The Vega's (and GM's) reputation with the aluminum engine was destroyed before unleaded gas was introduced. Briggs & Stratton was able to make aluminum blocks and leaded fuel work.
I think the 8-6-4 Cadillac failed because computers weren't developed enough to handle the task. I think the new technology will be more successful.
in the one i had was a 1971 and i ran amoco lead free all the time. they where the only company that had it back then
