Door Wiring
Old Jun 17, 2005 | 10:20 PM
deisele75's Avatar
deisele75
This would be the cleanest way.... and it would look cool.
http://www.dakotadigital.com/index.c...rod/prd103.htm
Old Jun 17, 2005 | 10:22 PM
Mil1ion's Avatar
Mil1ion
Wouldn't they corrode quickly in a Humid environment ?
Old Jun 17, 2005 | 11:28 PM
deisele75's Avatar
deisele75
I never thought of that...... but they probably come with some kind of warranty against it.
Old Jun 17, 2005 | 11:45 PM
Torque1st's Avatar
Torque1st
Posting Legend
Those "Magnum Shooters" only work when the door is closed tho. For some wiring jobs I have used regular PVC jacketed electrical cable. I have used tubing and hose like the person in post #2. I have split the tubing on one end and used pop rivets or screws to secure it to the body then the other end slides thru a hole in the door. The wire goes thru the hose or tube and then loops inside the door to avoid too much flexing. The later model corrugated wiring conduits seem to split and crack pinching the wires and causing them to flex where they shouldn't, -part of planned obsolescence.
Old Jun 18, 2005 | 01:07 AM
wkeller's Avatar
wkeller
The shooters look like Jamb-Tacs but more circuits. Could be a good possibility...
Old Jun 18, 2005 | 12:25 PM
teds74ford's Avatar
teds74ford
I used rubber grommets on the doors and vacuum hose that fits tight in them. There is a hole in the doorway that is about 1.5" diameter up by the the top of the fender. I ran the hose up to it and through to the underside of the dash. I used WD40 to lube the wires and thread them in the hose. This way there is no chafing and they end up high in the dash above everything so the wires aren't droopng down. The hose doesn't stretch or anything, and the bottom grommet keeps it held in place.
Old Jul 8, 2005 | 08:26 PM
TurtleBoyPW5's Avatar
TurtleBoyPW5
Has anyone installed power windows and locks in there 73-79 trucks using the parts JC Whitney has?
such as this
http://www.jcwhitney.com/autoparts/P...ower%20windows
Old Jul 9, 2005 | 12:23 AM
'78 Custom's Avatar
'78 Custom
i've also been lookin into the power window kits from JCW, but on the door speaker thing, i kinda ghetto rigged mine, ran the speaker wire inside the rubber seal, and then in the door through a small slit that was in the bottom of the door, then put wire loom over it, doesn't look half bad, plus the speakers work , thats all that matters to me. Heh, with 4 6X9's and 2 10 inch subs behind the seat, front speakers are a must.
madpogue
25
Jan 4, 2023 06:59 AM
hasteranger
Apr 12, 2012 06:58 AM
Paul49
May 29, 2011 10:45 AM
alconk
Dec 6, 2008 07:16 AM
