engine size computation
Old Oct 8, 1999 | 12:52 PM
David's Avatar
David
How do you determine the cubic inches in an engine? What ever happened to calling them 302,351C,etc...instead of 4.9L,5.0L? It was sure easier to understand the old way.
Old Oct 8, 1999 | 03:41 PM
Pastmaster's Avatar
Pastmaster
to me anyhow, I know both the CID and the Liters for most of the engines pre-97. Whatever a person calls a motor is up to them. Most of the engines put in 80-96 trucks were used at least 20-25 years. Everyone knows these engines well. They (cid/Liters) didnt change at all.
I call the post-97 engines by their Liters because I dont know their Cid's except the 4.6 which is 281.
Evan A.K.A. PastMaster
1993 F-150 302/E40d XLT
1989 F-150 302/Aod 4x4 XLT Lariat
Old Oct 8, 1999 | 04:12 PM
Al's Avatar
Al
It's roughly 60.82 x the liters..
Old Oct 9, 1999 | 08:32 AM
David's Avatar
David
Thanks for info so far but, how do you obtain cubic inches in the first place? I know it relates to bore and stroke but thats all I know.
Old Oct 12, 1999 | 06:56 AM
Mulletwagon's Avatar
Mulletwagon
The cubic inches of an engine is actually the total volume displaced or "swept" by all the pistons. If you can imagine the volume swept by a piston as it moves from bottom dead center to top dead center, it would take the shape of a "cylinder" and look something like a Planters peanut can. Multiply that volume by eight (for a V-8) and voila, you get the total displacement. The actual formula for the volume of a cylinder you may recall as "pi x r-squared x h. A simplified formula for engines would be:
displacement = 3.1416 X (bore/2) X (bore/2) X (stroke) X (# cylinders)
For a small block 351 (or FE 352) the bore and stroke is 4.00 X 3.5. The math would be:
3.1416 X (4.00/2) X (4.00/2) X (3.50) X (8) = 351.86
Not really rocket science, but interesting. HTH
FL Panhandle
Old Oct 14, 1999 | 11:31 AM
David's Avatar
David
thanks for the formula. David
Old Oct 14, 1999 | 05:26 PM
Fast Eddie
Guest
Posts: n/a
