did the a/c conversion, now there is extra wires
I installed a factory a/c unit in my truck in went ok. i have 2 wires left to hook up and can't figure out where they go. one is orange and the other is red both are kind of heavy gauge wires i then see the same gauge orange wire and color going into the heater switch do i splice the wire into it. the red wire i am at a total loss it runs from the heater control all the way down to the heater box.
Hey! I just did the same thing to my truck. I got every wire hooked up, but I had to do a lot of learning about the different year model wiring harnesses.
Send me more info and I can hook you up.
What year is the truck? I'm assuming 75...right?
What year model is the harness that your trying to use?
Does the harness have a little silver relay that bolts to the bottom lip of the dash board?
Don't worry a bit. We can fix this pretty easy.
Doc
ON the main cab harness between the dash board and the fire wall where the old heater control panel plugged in, you should have bullet connectors. correct?
Now, on the A/C control panel harness that your pluging in now, does it have the same bullet connectors, or does it have the spade connectors?
On your orange wire, what type of connector is on it?
On your red wire, what type of connector is on it?
![Okay!](images/smilies2/thumb.gif)
Doc
Last edited by docholiday72tx; 06-16-2005 at 02:15 AM. Reason: A couple more questions just to make sure I get it right
That big red wire that your talking about has a black stripe on my truck, and it goes from the rheostat that you mentioned up to the control panel blower motor speed switch.
Forget all about the relay. In my haynes manual it doesn't show the broncos to have it.The red and orange wires....everything is plugged in except them to the control panel?
Doc
Doc
Dennis, I'm sure they are in that second picture (the one for under the dash) but I cant tell for sure because the wires arent labeled and it's hard to see where they are going. I'm pretty sure I know which wires he's talking about, but I can't remember for the life of me where they end up at the control panel. I'm half tempted to take my guage bezel back off to get a refresher course.
One problem is my wireing harness came from about a 77 model truck. The 75 -77 trucks had a relay between the blower switch and the blower motor. His harness came from a bronco, and my Haynes manual doesn't show the Bronco to have the same type of relay.
The red wire and the orange wire he is talking about should work like this: there is a big black plug that goes to the blower motor switch. The orange wire and red wire are both on that plug along with a green wire. The green wire is no problem he already has it. the orange wire is a short wire that goes from that big plug and should plug right in to the harness where his heater plugged in to before. The red wire is 2 wires in one place on that big plug. One wire goes to the box on the passenger side, the other wire is a short wire like the orange one that should also just plug right in to his main harness. That's the general idea of how mine worked.
Doc.
Doc.
Gashog,
Read my previous post again (number 9)
The red and orange wires do go to the big black plug for the blower motor switch. They both have short wires coming off of them that plug in to your main harness. Look at your main harness for a big brown wire. There should be bullet connectors on that wire. The Two bullet connectors may be plugged together. One is male and one is female. The 2 short wires coming off of the black plug (1 red, 1 orange) will plug in to the big brown wire. Either the red or the orange is male and the other female. Therefore they can only plug in one way. Don't unwrap the main harness, just look for the big brown wire and plug in there.
Doc
Doc
