1978 - 1996 Big Bronco
Transfer case has issues
Old Jun 15, 2005 | 09:21 PM
Freakazoid!'s Avatar
Freakazoid!
I just finished replacing the clutch/pressure plate and clutch slave. Everything went back together without problems. I even fixed the shifter boot (it was letting a lot of noise through). Now that it runs again, I am hearing a ton of noise from under the truck while accelerating or engine braking. It's a vibration/noise that kind of reminds me of those rumble controllers for playstation or nintendo. I can "feel" the noise by grabbing the transfer case shifter, and to be sure, I checked the regular shifter (no noise). During this past winter I had some strange things happen going in and out of 4x4 (truck would pull hard left after going back to 2WD unless I stopped and cycled back and forth between 2hi and 4lo a bunch of times). I haven't driven it much since March when the slave went out, but I'm thinking the transfer case needs a rebuild. What do you guys think? Is a home rebuild do-able, or best left to the pros?
Old Jun 15, 2005 | 10:53 PM
masseysbronco's Avatar
masseysbronco
if you got the money to take it to the pros i would. Even in 2WD you ain't going anywhere with $2000 T-case that blew apart because of a slight misalignment.
