swapplng cab
Old Jun 15, 2005 | 08:27 PM
mark alderson's Avatar
mark alderson
swapplng cab
i would like some tips on putting acab on a1965 f250.the cab is from a1965 f100 any help would be greatly appreciated.The existing cab mounts are completely rusted away and the floorpans are also.the f100 cab has some rust but is in better shape.please help.
Old Jun 16, 2005 | 05:55 AM
66fdtrucknut's Avatar
66fdtrucknut
I just did that myself, I completely gutted the cab, seat, doors, glass. They are front heavy. I made brackets out of 3 x 3 angle. bolted them to my seat bolts. I left them long and found the balance point to be like 12'' fwd of the seat, don't remember exactly. brought my engine hoist in and picked it up through the door opening. took it off by myself. I flipped my cab on it's back and did the floors, mid brace ,cab mounts, and por 15ed the bottom. Make sure you take the cab bolts all the way out, the old pucks like to stick to the frame. Good luck.
Charlie
Old Jun 16, 2005 | 06:53 AM
garbz2's Avatar
garbz2
2 wheel drive or four wheel drive it makes a difference.
Garbz
Old Jun 16, 2005 | 07:56 AM
mark alderson
swapping cab
[QUOTE=garbz2]2 wheel drive or four wheel drive it makes a differencarbz[/UOTE]
Old Jun 16, 2005 | 07:57 AM
mark alderson
2 wheel drive
Old Jun 16, 2005 | 08:03 AM
garbz2's Avatar
garbz2
Thanks
It will be a direct bot on.
Easiest way i have found is to use a cherry picker engine hoist with a four point harness of Webbing and trqansfer the cab over.
Or conn some friends to help. use four and it will go on easy. the more you remove the easier it is. No adult beverages untill done...
Garbz
Old Jun 16, 2005 | 12:57 PM
bertha66's Avatar
bertha66
I have changed the cab on my 66 F-100 4x4 two times using 2wd cabs and fond no defferance. I used a wide plank between the two frames and slid the cab over to my 4x4 frame, can be done alone if need be. I did all the repairs to the new cab, rust repair and under coating before putting it on the frame.
Old Jun 16, 2005 | 08:21 PM
mark alderson
thanks alot for the advice
Old Jun 17, 2005 | 06:38 AM
garbz2's Avatar
garbz2
66 F100 four wheel drive will be a standard 65 66 cab and will interchange. A 65 F100 and 65 66 F250 four wheel drive will use the old 61 to 64 cab.
Garbz
Brandon Harrison
34
Apr 13, 2014 12:17 AM
lefty rodan
May 23, 2011 10:52 AM
The Incredible Sloth
May 21, 2011 05:16 AM
mark alderson
Jun 19, 2005 07:58 AM
FOMOCO1965
Nov 5, 2004 08:28 AM
