Speedometer Problem (NOT A FUSE)
Old Jun 15, 2005 | 02:51 PM
Nkt71403's Avatar
Nkt71403
Any help with this problem would be greatly appreciated...I Have a 1997 Ford F350 PSD recently my speedometer and cruise control quit working. I replaced the fuse and started the truck drove about 10 feet and the fuse blew again......Any suggestions???
Old Jun 15, 2005 | 04:04 PM
Kwikkordead's Avatar
Kwikkordead
Hmmm, how about some piece of metal wedged against the VSS?
Old Jun 15, 2005 | 06:44 PM
ltfox's Avatar
ltfox
It could be in the speed sensor. I'd check their first. My dads 97 did the same thing. After alot of searching we found a short in the dome light in the rear driver side door. I think the dome lights, power mirrors, ect... are on the circut also so good luck and let us know what ya find. We finally noticed that opening and closeing that door effected when it blew.
Old Jun 15, 2005 | 09:18 PM
18vtx00's Avatar
18vtx00
Smile
VSS may have metal on it from the diff, get a new one very common and only like 30-40$$$ oem only!! good luck or if you have a scanner check the VSS datastream as you drive and make sure it is accurate and not hunting!!
Old Jun 15, 2005 | 09:33 PM
copper's Avatar
copper
Sorry but I have to ask what a VSS is?
Old Jun 15, 2005 | 09:46 PM
95psd's Avatar
95psd
Variable speed sensor?
Old Jun 16, 2005 | 12:13 AM
vancouverpower's Avatar
vancouverpower
vehicle speed sensor, it is located on top of the rear differential, near the pinion seal.
Old Jun 16, 2005 | 05:03 AM
rollnthunder_76's Avatar
rollnthunder_76
Where is the fuse located because my did the same thing?Figure start with the cheap stuff first.
Old Jun 16, 2005 | 06:43 PM
18vtx00's Avatar
18vtx00
Smile
look in the owners manual, for some reason ford does not list the fuse name on the lids. not sure why.
