1978 - 1996 Big Bronco
Transmission fuses
Old Jun 14, 2005 | 11:44 AM
sprayed's Avatar
sprayed
Transmission fuses
Hello all, I have been having problems with my E40D not shifting into 1st or 3rd....I can pull the shifter from park to drive and it tries to take off in drive....not 1st...and If I manually pull it to 2nd/1st gear....itll only go into 2nd gear...then straight to 4th....talked to several tranny shops and they seem to think it could be the solenoids or fuses to the main wiring harness....where can I find these fuses...I have looked inside at the fuse panel and outside at the distribution block...but nothing is labeled....any ideas?? BTW pulled the pan and there are no metal shavings...just burned fluid....hoping its not gonna require a rebuild...
