1978 - 1996 Big Bronco
Clutch equalizer bar?
Old Jun 14, 2005 | 11:24 AM
scurbiedog's Avatar
scurbiedog
Exclamation Clutch equalizer bar?
Please respond by private message if you can help.I'm not sure if this post is against the rules but I'm in dire need of a Clutch equalizer bar.If you have a 1980-1983 full size bronco or f-150 that you may be parting out I need an equalizer bar .Its part of the clutch peddle linkage for non hydraulic clutches.
It pivits between a brackett bolted on the drivers side frame and a point that comes off the side of the bell housing.It connects the bar coming out of the fire wall from the clutch peddle and the adjustable bar going to the clutch fork on the side of the c-6 standard transmission.
I have searched all of the junk yards here in San Antonio with no luck ,most here only have 1996 or newer junked cars and trucks.I also searched the web including Jeffs Bronco Graveyard with no luck there either.The dealer wants my first born for the bar and I also need the brackett that bolts on to the drivers side frame and the dealer would like my arm or leg wichever I can spare.
I need these parts as my bronco is my only vehichle.My bronco is a 1982 with a 300 straight 6 , c-6 standard transmission three speed with overdrive.Please guys if you have or know someone who can help please respond by private message A.S.A.P. Thanks, Mark.
The_Builder
Jun 21, 2013 01:32 AM
lisagoud
Nov 26, 2011 10:08 AM
Stealther
Jan 7, 2009 05:17 PM
cschulz
Oct 28, 2007 08:20 AM
scurbiedog
Jun 19, 2005 11:14 AM
