95 Horn Problem
Old Jun 14, 2005 | 06:20 AM
MRStace84's Avatar
MRStace84
95 Horn Problem
We have a 95 F250, Powerstroke diesel. Yesterday, the horn starting chirping. Futher investigation showed the horn realy was chattering. When we pushed the horn button on the steering wheel the horn stuck on, and we had to pull the relay to make it stop.
So, anyone have any ideas?
Old Jun 14, 2005 | 03:02 PM
javi2001's Avatar
javi2001
Replace relay, it has a lot of wear...
Old Jun 15, 2005 | 07:35 AM
MRStace84's Avatar
MRStace84
I did replace the relay, and it did not fix the problem.
Old Jun 15, 2005 | 09:16 AM
Roushians's Avatar
Roushians
Hmm, maybe the pushbuttons on the steering wheel are starting to fail (the springs) or possibly you spilled something sticky on your steering wheel and the switch is sticking.
Old Jun 15, 2005 | 09:18 AM
MRStace84's Avatar
MRStace84
Anyone know how hard it is to take apart the steering wheel and check the horn buttons?
Old Jun 15, 2005 | 04:31 PM
javi2001's Avatar
javi2001
Not too difficult to remove. By the way, the Horn electrical system requiered grund from Horn buttons to activate realy, it means if horn cable gets ground by an insulation failure it's going to sound also, check wire insulation at stering wheel also.
Old Jun 16, 2005 | 09:21 AM
Roushians's Avatar
Roushians
Yes, that is a possibility too, a very good possibility. The wire that goes from the push-buttons on the steering wheel all the way to the relay for the horn could have rubbed against the chassis (a sharp edge) and is causing a short
oft
13
Oct 17, 2014 08:18 PM
Mercai
Escape & Escape Hybrid
Jun 11, 2012 05:30 PM
YoungFordAddict66
Dec 31, 2009 10:17 PM
lionsteve
Jun 16, 2007 06:24 PM
bryan42
Jan 19, 2005 06:21 PM
