rear brakes
Old Jun 13, 2005 | 11:48 PM
davidmb's Avatar
davidmb
rear brakes
I am restoring a 1978 ford f100 in South Africa and only have part of the rear brakes and cannot find a diagram can anyone help with picture of the brake shoe assembly especially the lower spring and holder
thanks davidmb
Old Jun 14, 2005 | 12:07 AM
Ecuri's Avatar
Ecuri
www.classictruckshop.com/brake_rebuild.asp
This is for 67-72 but I can't see any difference to a 78, should be enough info to get you going (or stopping, as the case may be) GL
Old Jun 14, 2005 | 12:29 AM
davidmb's Avatar
davidmb
cheers Ecuri it helps a lot thanks for the quick reply as I only got the new brake drums yesterday and Know will be able to stop
Old Jun 14, 2005 | 12:42 AM
Ecuri's Avatar
Ecuri
I have noticed the backing plates on these trucks get grooves cut in them where the shoes land (three high spots per) that can seriously impede proper function. Check yours out. I don't think even the Chinese are making new backing plates, so I weld tthem back up and grind em back down flat, add a very small dab of grease so the shoes can slide easly. Hope I'm not telling you what you all ready know. BW
Old Jun 14, 2005 | 12:48 AM
Mil1ion's Avatar
Mil1ion
Here's a better one & it's on FTE
